I have 4 connector symbol, which are very similar.
All have a connector “0”, which is meant for the Mounting holes.
At ERC one of these 4 connector symbols generates this warning, that the Pin is connected to the net “MountingHoles” as well as GNDA:
For all 4 connector this pin is defined the same (actually the symbol were copied from each other at creation). I made the pins hidden, in order to have the text vertical.
If I change the net a little bit, the warning hopped to another connector:
This is how the pin is defined:
Finally I want this without a warning:
Any clue what’s going on her? Why does KiCad think that a net called the same as the pin name is connected?
Marko
