Pin Table Sorting by X/Y
I am creating a symbol for a 80-pin IC by editing a symbol of a similar 100-pin part in the same family. This was convenient because many of the pin names are the same, and only the pin numbers are different. Once I sorted out the symbol names and new positions in the symbol editor, I needed to renumber the pins.
Opened up the pin table, and I’m trying to get the rows in the correct sequence so I can quickly renumber them. I thought this would be easy because I could just sort by X then Y, or Y then X. However, this doesn’t work. The best I can figure from experimenting, When you sort by X (or Y), it completely forgets the order of previous searches. And the sort order of other coordinate is not sequential – it seems random, but I think it might be the order that the pin was placed on the original symbol.
There is no function to open a pin table for a subset of pins, which would solve my problem. In the PCB footprint editor, there is a function to re-sequence pin numbers by clicking on pins in order, but this doesn’t seem to be available in the symbol editor.
Finally, a minor thing I don’t see in the pin table, there is no way to fill a selected range of pins with a sequence (like you might do in a spreadsheet column, for example). In my case, renumbering 20 pins at a time, it’s no big deal to just type the numbers rapidly in sequence. But when I see users editing symbols with hundreds of pins, a fill sequence capability would be more helpful for those folks.
Am I missing something that would help me here? In the meantime, I just copied these groups of pins, 20 at a time, to a temporary empty symbol. There I could sort the pin table as expected and renumber them in the table. I could have also just lined all 80 pins at the same X coordinate, in hindsight.
Thanks for that. It’s on the list at least.
At first I thought the grouping option would help me. But it didn’t, because the selected pins aren’t put into the group in geometrical order. So for my edge case, it actually makes remembering harder.
I accidentally bumped into another related feature request that can also use a few thumbs up:
