Folks,
Is it possible, when you are modifying an existing track to make the editor route the track with the width of the track you’ve just “picked up” to modify, rather than it using the existing, selected width?
I find a lot when doing boards that I’ll’ve just used a chunky track size for laying power or ground tracks and go to modify a signal track which then tries to lay down a 50thou or similar kind of width around something like the processor. It makes sense to me, that the system should have the intelligence to say: “Ah, I’m picking up an 8 thou track, let’s continue routing with that size!”.
Thanks.
