I’m converting some scripts over to kicad 5.1.5, and everything is working apart from drawing areas on the board.
This used to work,
newarea = self.brd.InsertArea(0, 0, layer, FromMM(x1), FromMM(y1), pcbnew.CPolyLine.DIAGONAL_EDGE)
but now I get a error because pcbnew no longer has CPolyLine.DIAGONAL_EDGE.
Looks from https://docs.kicad.org/doxygen-python/pcbnew_8py.html it might now be
pcbnew.ZONE_CONTAINER_DIAGONAL_EDGE. However this isn’t in my pcbnew python module.
Any ideas on how I can create rectangular areas on silkscreen without this?
Thanks,
Matt
After a frustrating couple of hours I have a version that works with kicad5.
The DIAGONAL_EDGE constant moved to the ZONE_CONTAINER class, and the AddFilledPolygon method changed name to SetFilledPolysList.
This is what is now needed to add a filled area to a board:
newarea = self.brd.InsertArea(0, 0, layer, FromMM(x1), FromMM(y1), pcbnew.ZONE_CONTAINER.DIAGONAL_EDGE)
poly_set = pcbnew.SHAPE_POLY_SET()
poly_set.NewOutline()
poly_set.Append(FromMM(x1),FromMM(y1))
poly_set.Append(FromMM(x2),FromMM(y1))
poly_set.Append(FromMM(x2),FromMM(y2))
poly_set.Append(FromMM(x1),FromMM(y2))
newarea.SetFilledPolysList(poly_set)
Hope this helps someone!
system
Closed
3
