Using the above script, this is the result POS files.
Placement is correct, but rotation is build-relative, so (of course) that varies depending on how the decals sit in the library.
It is corrected visually in a few seconds, with some 'R’otates…
### Module positions - created on 06/30/16 21:14:26 ###
### Printed by Pcbnew version pcbnew (2016-06-19 BZR 6943, Git e27f90a)-product
## Unit = inches, Angle = deg.
## Side : top
# Ref Val Package PosX PosY Rot Side
D1 LED LED_1206 3.5350 1.5650 45.0000 top
D2 LED LED_1206 3.4650 0.5650 315.0000 top
Q1 +5VREG TO-263-3Lead 3.1000 1.2000 90.0000 top
R1 12k R_1206 2.0500 0.5500 0.0000 top
R2 12k R_1206 2.0500 1.2000 0.0000 top
R5 12k R_1206 0.4000 1.7000 0.0000 top
R6 10k R_1206 3.6750 0.9250 255.0000 top
R7 10k R_1206 3.6750 1.2750 105.0000 top
U1 87C256 SOIC-28_7.5x17.9mm_Pitch1.27mm 1.4000 0.8000 90.0000 top
U2 87C256 SOIC-28_7.5x17.9mm_Pitch1.27mm 1.4000 1.4500 90.0000 top
U3 AM100415 SOIC-16_3.9x9.9mm_Pitch1.27mm 2.0500 0.8000 90.0000 top
U4 AM100415 SOIC-16_3.9x9.9mm_Pitch1.27mm 2.0500 1.4500 90.0000 top
U5 CD4001B SOIC-14_3.9x8.7mm_Pitch1.27mm 0.7500 1.6000 90.0000 top
U6 CD4069 SOIC-14_3.9x8.7mm_Pitch1.27mm 0.7500 1.2500 90.0000 top
U7 PAL16R8 SOIC-20_7.5x12.8mm_Pitch1.27mm 0.6500 0.8000 90.0000 top
Y1 24-576MHZ Crystal_SMD_7050_4Pads 0.4000 1.4000 90.0000 top
## End
## Side : bottom
C1 .1uf C_1206 1.1500 1.0000 180.0000 bottom
C2 .1uf C_1206 0.5000 1.0000 180.0000 bottom
C3 .1uf C_1206 1.9500 1.5500 180.0000 bottom
C4 .1uf C_1206 0.7000 1.7000 180.0000 bottom
C5 .1uf C_1206 0.7000 1.3500 180.0000 bottom
C6 .1uf C_1206 1.9500 0.9000 180.0000 bottom
C7 .1uf C_1206 0.4000 1.5500 180.0000 bottom
C10 .1uf C_1206 1.1500 1.6500 180.0000 bottom
## End
