There is a track with a length of 300nm, and that is quite short
You can use the buttons in the toolbar on the left side to view tracks, pads and/or via’s in “outline mode”.
But you have a lot of those things. A better solution may be: PCB Editor / Tools / Cleanup Tracks and Via’s.
Aditionally:
Try to keep posted screenshots small. Not everybody has a high resolution monitor, and when big bitmaps are posted, the forum software scales them down a lot, which makes texts very small.
I did use the tool Cleanup.
But you know what? Repeating the use, it was cleaning again. So: only one pass wes not sufficient.
Strange.
i will keep in mind to run it several times, from now on.
Ok for the pictures. I try to make them smaller, although I see there is just a file name … no handles to resize them … so I have to resize them upfront the paste here
No need to make everything beforehand, when you include a picture in a post you can select how you wish it to be displayed at the bottom when you hover on top of the picture (100% 75% 50% etc.)
Ok now it’s clear. I was uploading the picture just by pasting it. and clicking on REPLY. I see in the lower right corner the “preview button”. If I click it, then I get the same your screen.
