I’m wondering how you’re supposed to use the Track and Via drop-downs in PCB new.
I see you can add more items using Design Rules > Global Design Rules. But then what?
The only thing I seem to be able to do with these controls is to set the track or via size that the tool will use for subsequently-added tracks or vias.
What I was expecting was that there would be some way to apply those settings to existing tracks/vias. Like select the track and then right-click > something.
There are UI elements to change the track or via size:
In OpenGL, right-click > Properties lest you change track width, but by typing in a new value, not picking from a list.
In Legacy display mode, when you right-click on a track, there’s an item “Change track width”, which does nothing – no dialog appears, and no change on the drawing. There’s also “Select track width”, but it doesn’t seem to affect the track, just changes the drop-downs.
Am I missing something here? How are these drop-downs, and the multiple global track/via settings supposed to be used?
“Change track width” and “Change segment width” change the width of the track/segment to the currently selected width. So use “Select track width” to set the width, and then “Change track/segment width” to change the width of tracks.
Huh, yes that works, at least in Legacy mode. Thanks, it would never have occurred to me that’s what those menu items mean!
So, we might call the drop-downs the “Active Track/Via configurations (for unclassed tracks/vias)”. Then the right-click menu items would be:
– Set Active Track configuration (currently: Select Track Width)
– Set Active Via configuration (currently: no existing item)
– Apply Active Track/Segment configuration (currently: Change Track/Segment Width)
– Apply Active Via configuration (currently: Change Via Size and Drill )
I notice that the Active track configuration, and the Global Design Rules it chooses from, doesn’t include a clearance spec. It seems a bit odd to accommodate ad hoc adjustment for current (width) but not for voltage (clearance).
Anyhow, is there a way to perform these same functions in the OpenGL UI?
