Hi, I just installed KK on win10 details below:
Application: KiCad
Version: (5.1.4)-1, release build
wxWidgets 3.0.4
libcurl/7.61.1 OpenSSL/1.1.1 (WinSSL) zlib/1.2.11 brotli/1.0.6 libidn2/2.0.5 libpsl/0.20.2 (+libidn2/2.0.5) nghttp2/1.34.0
Boost: 1.68.0
Curl: 7.61.1
Compiler: GCC 8.2.0 with C++ ABI 1013
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
I pulled in an existing design done with same version KK on Win7, and changed my footprints and track colours over between top and bottom Cu. This left an SOT23 - 5 base in the wrong colours on my screen, even after changing them in footprint editor after which they were correct. When I tried to delete the base, PCBnew shut down. Tried again and same issue PCBnew shut down.
The problem was solved eventually, the base was locked. After unlocking it was removable and replaceable with the changed colours. If I lock it again, deleting it shuts the program down.
Is this reportable as a bug?
