Hi
I must be doing something really dumb, because using the modern interface in PCB new, I can’t see a way to route tracks other than at multiples of 45 deg when I first draw a trace.
Pressing D of for “Drag (free angle)” does not change the routing when first creating a trace.
It pressing D however does work, if I create a short stub of trace and then drag one end to where the connection really needs to go.
I’m using the latest version (5.1) on Windows 7, and the Modern interface.
I’m confused here. Here (KiCad V5.1.6 “Modern Toolset Accelerated”) the D for Drag really likes to put track segments back on a multiple of 45 degrees.
G however moves a corner (or endpoint) of a track and does it under any angle.
The workaround seems to be to make a very short stub of trace, and then Drag it to the desired end point, which is what I’ve started to do here, with the traces which are at approx 30 deg
Your current way seems to be a reasonable workaround with KiCad trying to maintain 45 degree track angles. the track segment does not have to be particulary “short”, cause when you drag an enpoint with G the length is also adjusted.
In your design you have lots of short tracks under different angles. Track segments can be easily copied and reused for another net. Just hover over any track segment, pres [Ctrl + D] to duplicate it, which grabs it by an enpoint, and then place that endpoint onto a pad of a different net. [Ctrl + D] works on the current selection, so multiple track segments can be copied.
Even slightly faster is probably to first draw it with 45 degree angles, from pad to pad, because KiCad ends drawing a track on a pad, and then use G to drag the unwanted corner into the pad.
Switching the interactive router back and forth to “free angle mode” is a bit of a nuisance if you have to do it often. You can experiment a bit with using the Interactive router in “Free Angle Mode”, and then draw an approximation of the parts you want in multiples of 45 degrees, and then later clean it up with the D key, which puts segments back in multiple of 45 degrees.
These are all slight variations of the same thing. but it’s a result of mixing free angle mode and 45 degree angle mode. Having shortcut keys to switch between these would help, or even 2 different keys to start a track. X for 45 degree mode and Z for Free Angle mode. But that’s currently not implemented, may be doable with a simple script, but I have no knowledge of KiCad scripting.
I’m OK using my work-around. With some tracks, the dog-legs can’t be avoided.
I could use a plugin I found which makes rounded corners, but it creates multiple very short tracks, and is only useful when the routing is finished, as it would be difficult to edit.
I’ll see if I can close this thread, and if not… Moderators please feel free to close it as resolved via work-around
