PCBNew: how to change layer and/or thickness to group of objects and/or bulk?
I want to change the thickness to this group, from 0.7 to 0.1mm
But I can’t. The same if I want to change the layer of this group.
Is there a way to bulk these operations?
In this case are graphical lines, uploaded into Silkscreen
a little bit information would be nice. graphical items (lines?) on silkscreen-layer?
The parameters of graphical items can be bulk-edited with the Edit–>Edit text and Graphics Propertis dialog.
Right I edited my post.
Those are graphical lines loaded into the silkscreen layer
Your suggestion edits the whole stuff when I need to edit only that group
You should be able to do that pretty easily with Edit → Edit Text & Graphics Properties, as @mf_ibfeew says.
You can check the “only include selected items” box to make it only work on what you have selected.
No I can’t since this doesn’t edit the selected group but the whole layer. Which I no want.
Using this box should limit it to only work on what you’ve selected, not the whole layer.
When you say “group” are you referring specifically to the feature called “Groups”, where multiple items can be grouped together into one item, or are you just referring to a selection of multiple items?
Right question. I’m talking about grouped items
And you want to edit some of the items in the group, but not all of them?
Exactly, and I created a subgroup and I want to edit only that
Just tested, works also with subgroup. You have selected only the items of the subgroup? Can you post a picture of your settings in the “Edit Text and graphics properties” dialog?
I drew a bunch of lines on F.Silk. I grouped some of them. Then I tried to move the group to the B.Silk and make them wider. This worked fine – I don’t think I understand the problem.
Before (group selected):
Action (group still selected):
After:
If that’s different than what you want to do, please explain in detail what the group configuration is and what you’re trying to act on.
Ok I see my error. I didn’t select PCB graphic items
