I’ve been using build 5112 of Kicad without much incident. I’ve laid out half a dozen or so small boards, routed the important tracks with the p&s router and then handed it over to Java-based Freerouting app. I just finished placing the components of a larger board (ie. several days work) and Freerouting can’t import the DSN that PCBNew generates for this file. If I delete all the components/images/nets/wires from the DSN file I can load the blank board with just the ground planes, so it isn’t related to an incomplete outline. All the component names seem to check out and the spectra DSN format seems to tolerate spaces and funny characters (“μ:,” ", “~”., etc.) for component and part names.
I don’t get any exception message, Freerouting just on the ‘Loading design…’ dialog forever.
Any tips? I’ve picked through the DSN file a bit but nothing obvious is jumping out at me compared to other DSN files that Freerouting can open. Changing ‘suspect’ characters hasn’t helped. I just can’t figure out what is tripping up Freerouting.
Bah. Tried to post a link to the DSN file but am too new a user.
