This might be very complicated to implement or is intended the way it works now, but wanted to check. When I make modification to a board using the Python interface, e.g. adding a track or a via, the board is not marked as modified in PCBNew. If I save, the changes are saved, but no asterisk * is indicating that it is needed. If you think this is a bug, then I can submit one, but maybe this is intended?
It’s not a bug. Current api gives you direct access into kicad’s inner workings, it’s not watching what you are doing to know when you have modified things. If you use the plugin system then it’s smarter about it and will save changes in undo system as well as mark the board as modified.
If you are doing stuff directly in scripting console then it’s the wild west, you can do whatever.
