I’m designing a CAD housing for a PCB and need footprint positions relative to the PCB center point. Up until now I’ve manually calculated for basic footprint positioning using the edges co-ords but it’s a nightmare.
I thought it i’d set the PCB grid origin (as shown) that would do it, but alas not.
Position the cursor at the PCB center and press space. This sets the relative coordinate origin, the relative coordinate is displayed in the status bar.
Why set the origin to the center of the board?
It seems more logical to set the origin to a corner of the board or the center of a mounting hole or maybe even a fiducial as a reference point.
You can also export the whole board (including 3D components).
(Is this “step up” or was “step up” the other way around).
Then you can simply design the housing around your board in the CAD package.
Perhaps because the op has mentioned several times that he/she wants measurements relative to the center of the board?
Yes, most of us would likely reference a mounting hole if there was one, otherwise a board corner as this more directly translates to the mechanical design of an enclosure. But that’s not what the op asked.
The rest of your post is just a repeat of what has already been said.
That’s it, for example I want the exact centre point of the USB port so I can get the enclosure that goes over it correct in CAD. I could export the mock as you say but it’s not ideal for accuracy.
I’d be happy to set the origin to the edge of the board, any means to avoid running calculations based on the edges. I can’t forsee a means to do this, it appears measures are always relative to the page corner.
Recently I wrote a script to get positions for all components, since a forum user expressed a requirement. You can find it here
If you set the “origin for drill and place files” then it will give positions relative to that point. The component position depends on the center of the component is defined.
