Pcbnew is refusing to open in Ubuntu 18.04. I have projects that I have been working on that open the schematic but fail on PCBnew. I have tried different projects getting the same result. When trying the projects on a windows machine they open with no issue.
I also tried opening opening PCBnew individually (without the project explorer) it did not open.
I would appreciate any help or directions on where to find log files with info.
The command you gave above returns an error. I suppose that means I’m not running the “bog-standard 4.07”. Any other ideas on how I can get the crash report?
I followed advice to try installing the nightly build and it worked. So I will just stick with it. If you prefer staying on the stable release I suggest you wait for a patch from the devs.
