I am redesigning a board in Kicad 5.0/Windows 10 32bit and I ripped up some nets. I used delete and the selected routed nets became airwires, which is OK. But when I hit DEL on a GND route it simply disapeares; I can’t see the airwire instead! The pins are still connected to GND, they all are selected when highlight the net in Inspect -> List Nets so the netlist is OK. So the only issue is I can’t see the airwires and that’s confusing and can mislead me to think all the board is fully routed.
I have a ground plane, indeed, but it’s not disabled. Shouldn’t I see the airwire even in this case? I’m not sure the ground plane would cover all the areas eventually. Or it will have the required thickness, without thin bottlenecks.
I see your point. The groundplane ties all pand in realtime and if I route something else in the way, only then I’ll have airframes for the inaccessible pads. Cool!
You can see it for yourself if you enable full visibility of copper zones. Top button on this picture:
Copper zones don’t update in realtime because it would be performance killer on big boards. Instead you can manually rebuild them by pressing B. They are also updated on some actions like DRC check and maybe project open/save.
