If I want to get two versions of printed circuit boards from one diagram (different layout / arrangement of elements / board dimensions), then it does not have a button for updating elements from the diagram. I don’t want to do this through netlist, it’s inconvenient and takes a long time. How can you solve that problem?
The update button only appears if you have opened the schematic or layout via the project file, not in standalone mode. Since the schematic and PCB files are matched by name, it means only one PCB file can be associated with the schematic file. If you want to derive another layout, then clone the project to a new project directory and create a different layout from the schematic.
