I wonder if it is correct create traces from a fill zone as shown in the following image (3D + layout):
DRC test passed.
Could you tell me if this is allowed? It could be a problem during PCB creation?
Thanks in advance for any reply.
DRC test passed.
I would probably put a via where the track ends or route it to one of the existing vias, to give the track smth. to lock in. But otherwise this should be fine.
Why not.
I would not expect any problem in PCB manufacturing.
The only advantage of your solution compared to just simply using wide track is that you have thermal relief connections of elements to that wide track. But practically I don’t think wide track makes any problem with soldering so I would not use your solution.
