PCB rotatated and translated in VRML
My 3d model looks OK but when I export to VRML the board and the parts are rotated and
translated away from each other:
What VRML viewer are you using?
What kicad version are you using?
5.9.1-1 release
solidworks import
thanks!
VRML might not be the ideal solution to import into solidworks (unless i misunderstand what solidworks is). Might be better to use step here. See What is the difference between step and wrl 3d models?
Thanks :slight_smile: Though I wonder about the mistake in the vrml step is perfect.
