Got a weird bug that I don’t know how to get around.
The PCB in the PCB editor when opened from the project folder looks like this:
The only things rendered are ratlines and some stuff added by hand (a couple of silkscreen lines and some copper polygons).
When I open the same file in stand-alone (copy it to a different folder) it looks just fine.
dsa-t
2
This would happen if you open a 9.0 project in 8.0.8 or older.
Delete the .kicad_prl
file or just enable visibility for the items in Appearance panel → Objects tab.
Thanks, it worked.
It was a 8 project, but I worked on it in 9 for a while and it was fine until some point in time.
system
Closed
4
