Hi Guy’s,
I am just wondering if anyone can tell me if there is an easy what to select single nested items within a group.
Let’s say you group two footprints together a resistor and a capacitor and then you also group two transistors together. Then you group then above two groups together. So you can move them around in the board layout easily.
But, and here’s the question.
Is there an easy way to select a single element from within the group. For example, the resistors reference label from the first group.
I have used some software before that all you need to do was hold ctr and you could select easily select nested elements without having to unmake or remake groups, or in this case from what I can see enter groups over and over until you get to the element you’re interested in.
