After I poured my Power and Ground layer I noticed a number of horizontal lines on the PCB. I’m wondering what they are and what the purpose of them is? I’m pretty sure I didn’t put them in…
What is your Copper Zone Properties - Fill Mode setting, Polygon or Segment?
Is it possible the renderer is partly stuck in the “show outline” view mode (left toolbar)
If this is the case restarting pcb_new might help.
I think those are merely an artifact of how polygon fill works.
Polygon Fill has to draw a path that defines the outside of an area, and then fills that, but the holes need to be outside the polygon - to achieve that, the polygon breaks at the edges and then comes in, around the hole, and out again, and mathematically the hole is now outside the fill area. Quite clever.
( Just like the food you digest, is outside your body )
True, the gerber file only accepts non-intersecting polygons… although I don’t think the method used is the only solution, maybe it is the easiest.
Yeah, isn’t that weird !?
