PCB Footprints are not coming to layout window while importing from schematic
Dear Team,
I clicked update pcb from schematic.2 errors and some warnings are present.
Only lines are coming in the layout editor.Please see below.May I know how to solve this issue.
Always tell version number.
I have still installed V8.0.9. I don’t expect such bug in V8 so for V8 I would say - you have probably filtered out several layers or kind of Objects.
Buf for V9 I don’t know. May be it is known bug with first (zero) release and you will be told to install later version.
Same question has popped up a few times lately. See for example the thread below.
I am using Kicad 9.As suggested I removed “kicad_prl” file and it is working properly.Thank you.
Thanks for the tip, it worked like magic. How did you figure out this solution?
