PCB filename string replacement
I would like to have a text item on my PCB with a text replacement variable that is the name of the PCB file but I couldn’t find how to do it since FILENAME isn’t part of the PCB editor (it seems) only for worksheet.
The idea would be to create a template project and use the project/pcb name to name the board automatically.
Maybe there is another way to do it?
Thank you.
I would use the title variable, this would make more sense than the filename, because sometimes the file is called “ugly_cat” so you might as well call it “ugly cat”. you use the variable ${title}
as seen here
I thought of using title but, the idea is that when I rename my template, I give my project a name and that name is reused across all the files: schematics and PCB.
Also the Title would be the name of my entire project + the name of that specific board.
My project is a set of stackable boards with the same size, with different functions. and I prefer to have each PCBs in a different kicad project instead of one kicad project with multiple PCBs.
You could go ahead and log an enhancement request.
