PCB Editor Warning!
hello everybody
I am starting to watch this playlist
https://www.youtube.com/watchv=jaQPr7PgImk&list=PL3bNyZYHcRSUhUXUt51W6nKvxx2ORvUQB&index=7
I want to fix all warning errors for this footprint of the 7555 badge as a playlist but this next warning I cannot fix it.
That error is telling you essentially that silkscreen print is going over the top pad of the battery holder footprint. You should adjust the silkscreen lines (in light yellow) so they have some clearance to the pad. Otherwise some manufacturers would print the silkscreen on top of the pad, which would be bad. (Many manufacturers automatically remove silkscreen overlapping pads, but it’s not a good idea to rely on that)
thanks so much, Mr.Haas
