Hi
I’m having an issue with Kicad where the PCB editor won’t open, it appears to open and I can view it in the task bar - which shows it as a blank white window - but if I try to bring it to focus it nothing happens. I’ve tried opening the editor from the project manager as well as from the schematic. At first I had some warnings when updating the pcb from schematic but they are all fixed now. I’ve also tried old files that were working and the same thing happens. I updated Kicad about 2 days ago with no change.
There is a .lck file that appears when I open it, deleting that doesn’t seem to have any effect.
I have used some custom libraries and made one or two myself, I don’t know if that could have any effect. I tried turning them off in library manager and it didn’t seem to make a difference.
I am using using Windows 11. Here is the Kicad info.
Thanks for any help ![]()
Application: KiCad x64 on x64
Version: 7.0.8, release build
wxWidgets 3.2.2
FreeType 2.12.1
HarfBuzz 6.0.0
FontConfig 2.14.1
libcurl/7.88.1-DEV Schannel zlib/1.2.13
Platform: Windows 11 (build 22621), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Sep 29 2023 18:44:47
wxWidgets: 3.2.2 (wchar_t,wx containers)
Boost: 1.81.0
OCC: 7.7.1
Curl: 7.88.1-DEV
ngspice: 41
KICAD_SPICE=ON
