PCB Editor does not make aperture for through hole component pads
Here’s a small section of pcb layout.
I’m getting errors about hole clearance and solder mask bridging, and it’s reasonably obvious why - there is no aperture made in the zone for the through hole.
But why not? And why only for this particular piece of the zone (as far as I can tell). These two components are not even connected to anything in the schematic, so the two pads have different nets from each other, as well as from the zone.
I’ve never seen this happen before, and I’m stumped at the moment.
Can you upload an image of the issue, or attach the project?
It’s difficult to understand what is happening with out more information.
What version of KiCAD are you using?
The version is 7.0.2.
As is the way with these things, I made some progress shortly after posting, by moving some traces a bit, to ensure that the piece of the zone is not considered an island. I speculate that there is some internal inconsistency about exactly what constitutes an island, or exactly when this is determined, but I’ve never looked at the code base, so speculation is all it is.
It simply have no sense to use this version.
Use 7.0.11 (or 8.0.9) Each minor number change can be even 100 bugs fixed so your version can have even 900 bugs more than 7.0.11.
