My Problem is, the PCB Editor is crashing after 10 seconds. If I open it with console the last messages are:
=> kicad
terminate called after throwing an instance of ‘std::runtime_error’
what(): Error: unmapping vertices buffer: invalid operation
Aborted (core dumped)
The same on a other windows 10 PC but on two other windows 10 pc´s its working.
If you can share the design, please file a bug report here https://bugs.launchpad.net/kicad with it attached so we can hopefully figure out why it is crashing.
I have the same or similar problem.
My Laptop HP Envy 360 couple years old
I think version 4 or Kicad worked for me on this machine, however I reinstalled it and have same schematic open then crash problem. I have installed Kicad on Windows 7 and Linux Mint on VM machines (hose this HP laptop) on VM environment Kicad appears to work fine. I have installed these versions
kicad-4.0.7-x86_64
kicad-5.1.2_2-x86_64
kicad-5.1.4_1-i686 32bit
kicad-5.1.4_1-x86_64
kicad-night build-r14232.64b5e8bee-i686
All with same crash result… open schematic about 5 seconds later crash, no message just disappears on screen. I have several other Dell XPS8900 machines KiCAD works fine on them no issues.
At this point I am lost. Any help would be appreciated.
-------- currently installed version below -------
Application: KiCad
Version: (5.99.0-126-g64b5e8bee), release build
wxWidgets 3.0.4
libcurl/7.61.1 OpenSSL/1.1.1 (WinSSL) zlib/1.2.11 brotli/1.0.6 libidn2/2.0.5 libpsl/0.21.0 (+libidn2/2.1.1) nghttp2/1.34.0
Boost: 1.68.0
Curl: 7.61.1
Compiler: GCC 7.3.0 with C++ ABI 1011
