This may be a bug, so I’m asking for others to check.
If I drag the top frame of the Selection Filter Tool Window up or down the Selection Filter Tool Window disappears. I haven’t found a menu item to restore it.
If I close then re-open PCB Editor the Tool Window is again visible.
Application: KiCad (64-bit)
Version: (6.0.0), release build
wxWidgets 3.1.5
libcurl/7.78.0-DEV Schannel zlib/1.2.11
Platform: Windows 10 (build 19043), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Dec 24 2021 19:17:02
wxWidgets: 3.1.5 (wchar_t,wx containers)
Boost: 1.76.0
OCC: 7.5.0
Curl: 7.78.0-DEV
ngspice: 35
Compiler: Visual C++ 1929 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
