How i can create something similar to this coating. Help pls
There are Two aspects to this question:
In your photo the edge plating is likely required for contact between the PCB and a metal part which will be placed adjacent. If you need such a feature fine. If not, it is an expensive and unnecessary extra.
If you just need the RF shield effect, via stitching near the board edge is a much cheaper alternative
hola david, a que te refieres?
Mod edit: English translation:
Hi David, what do you mean?
I have seen edge plating as a way to bond top and bottom layer ground planes together. This then makes a complete shield like a box around inner layer tracks.
Simply making a line of closely spaced via holes near the board edge has a very similar effect. It is called via stitching and is much cheaper, as it does not require extra process steps.
There is a KiCad plugin to help making these vias.
