true
but i would assume the centerline as below
I would put the center(line) where the center has been specified by the manufacturer (not the case here afaik) OR where the FPC cable ends in the device.
The FPC cable ends 2.1 mm from the āinsertion edgeā inside the device.
From the insertion edge itās 4.9 mm to the lever side of the device and as per the side drawing the pins stick out a further 0.3 mm (0.6 - (5.2 - 4.9)).
The y dimension of the pads is 1.1, where as the pins are 0.6 mm, normally centered this would give a distance of 0.25 mm to in vertical direction to the pad edge, but they specced 0.2 mm at the āupperā side there. This means the pad center is vertically shifted down by 0.05 mm vs the pin center.
So the (negative) y value for the pads then comes to 2.75 mm (4.9 - 2.1 - 0.05).
Thatās OK, not perfect, but OK. Always work from the dimensions, never from what you see, unless you have no other choice.
They just forgot to put in those separation marks, that tell the reader that the drawing only shows the most right and left parts with some pins and leaves out the middle of the device, that is just repetitiveā¦
centerline was a bad word by me
i meant just reference line or something to align body to pads in this specific case
Omron_XF2M_0.5_40P_SIDE.kicad_mod (7.2 KB)
but two pads 41 that are not next to each others is not nice
technically they belong to the same net
if kicad was strict would create an open net unless connected
thanks Joan
one question
Regards
Hm⦠I usually just use a generic 41 pin symbol and use pin 41 to connect to ground⦠others might use a more sophisticated symbol that will depict pin 41 as housing ground or etcā¦
How would you number them?
You need to ask that the guys with more experience than meā¦
I went over my private libs about 2 months ago and added F.Fab - I had that info on Dwgs.User/Cmts.User before and F.CrtYd was added by me as well then and there.
I then checked the boards I already did by swapping the footprints for the upgraded ones and found, that I placed most devices with Courtyards touching⦠if any of those boards would need to go to an assembler this will be very important.
F.Fab is needed for me to see the layout in 2D. I canāt do without those device outlines anymore⦠just pads is not enough and the Silkscreen layer is OFF when I do layout as itās distracting and lacking information.
it was 42 pins
40 signals and 2 dummies
the dummies should probably go nowhere
in some cases atleast they should not go to ground or anywhere
so i would just follow from last siggnal 40 to 41 and 42
ps
in mentor tools when you draw 2 pads with same pin-number in footprrint editor (cell) you acctually get a ratsnet in footprint editor between the 2 pads
ds
PCBnew does similar stuff for same numbered pads in a layout when you connect only one of the pins to the respective net..
makes perfect sense
they are the same net
and if not intended to go to gnd it will give an open net
and you dont want to route a trace just to clear that
thanks nicholas even if i number those pads as 41 and 42 they are not connected to any thing does kicad not complain saying these pads are not connected any where
@Nick123
In case you want to use that fp, download it again (I updated it up there)⦠the create-a-new-footprint-wizard screwed me over with the reference field⦠I just edited the file and made it how I think it should be:
That way one can switch off Silkscreen during layout and also disable reference/value in render tab during layout, without loosing the F.Fab outlines infoā¦
The wizard had confused me⦠REF** was on F.Silk and %R on F.Fab (I also had %R the wrong way around and put in R%).
no because they are not connected in the schematics
2 loose pins without connections in the netlist
thanks nicholas i got it
Joan Sparky
in this diagram F.Fab(yellow line) crossing over on both pads 41 does this not impact the signal on that pad
lets assume for now if 41 pad was a real signal pad connected to some X pin to the processor ?
Regards
nick
so basically F.Fab is for our easy while doing the PCB designing just wanted to make myself clear that this layer is not needed by the PCB fabricator
The only layers that are needed to make a pcb are:
x.Cu (and other copper layers if more than 2 layers)
x.Mask
If you want silkscreen, then you also need
x.Silk
If you want a solder paste stencil you also need
x.Paste
If you want to define the outline of the board (otherwise boardhouse just uses rectangular largest dimensions that keep all the stuff above āon boardā) you will also need
Edge.Cuts
Youāll also be able to output a drill file if you put down vias or through holesā¦
Any other layer is for documentation or assembly or layout help and will not do anything to the gerber output afaik.
x.CrtdYd is for you to make sure you donāt put one device into another and/or give the assembly machine enough space to put the SMDās down
x.Fab is for you during layout or someone else as documentation later which device sits where and how
