I have a DXF file (it is a sketch from Fusion 360) and I want to use it as a template for a PCB. By template I mean being able to create hole/vias on the vertexes of my DXF and trace tracks on the edges.
It doesn’t. Or I didn’t understand in which graphic layer. Because when I imported it, I couldn’t place vias on the vertexes of my design or place tracks on the edges
I first imported a DXF file as Edge.Cuts and was able to put all the vias (setting the user origin to the center of each circle on my skecth and then moving the vias to the user origin). Then I imported another DXF file as F.Paste (red lines) but I can’t join them to my vias with tracks
Unable to join would be because they don’t belong to the same net. In fact if you started out without a schematic there would not be a netlist at all unless you write one by hand and load into the PCB.
Some of the layers in KiCad are for general use, while other layers have very specific meanings.
The “F”, and “B” prefixes are for Front and Back of the PCB. while “Paste” is a solder paste layer, which is used for creating solder paste stencils. Tracks can only be drawn on copper layers, for a 2 layer board these are F.Cu and B.Cu.
Did you also do the layout in that other program, or did you draw those spirals in a CAD program? “Gerbview” is a gerber viewer in KiCad, and it can recover parts of PCB layouts from gerber files and export them to a KiCad PCB file.
Graphics import seems to be disabled for copper layers, which I find quite annoying. At the moment copying of blocks of data between Copper and non-copper layers is alsodifficult or impossible. Things like these are also a moving target and have changed between KiCad V5.0.2 and V5.1.
I’m almost certain this will work:
1). Generate gerber files from your current BCB in Pcbnew.
2). Open the Gerbers in Gerbview, and export them to Pcbnew again.
3). Continue in Pcbnew with the newly created PCB.
Gerbview is a pretty dumb program, and it does not know which layer is which. It does not make any distinction between a Silksceen or a Copper layer.
When you back-export from Gerbview, you have an option for each gerber file to which KiCad layer you want to export.
Working with graphics is … a bit limited in KiCad, and clearly not polished.
For example, with .svg graphics you have other options than with .dxf graphics.
Another option is to edit a KiCad PCB in a text editor. It’s all readable text and the format is not so difficult and the file formats are also documented on the KiCad site (One of the many advantages of Open Source programs).
Yet another option may be to use FreeCAD in combination with StepUP, but I would not recommend this for beginners, because of the learning curve.
Edit: Addition.
When you are drawing tracks in KiCad, the “Interactive Router” is quite agressive in pushing tracks aside to make room for a new track. In your case I assume you want to preserve the spirals. To prevent the “Interactive Router” from changing existing tracks you can change it’s settings from “Shove” to “Walkaround”.
You can find this setting in:
It looks very weird to me though.
There are no components on the board (resistors, capacitors, IC’s, transistors, etc) and therefore it seems to do “nothing”. I can only guess what the intention of this pcb is. Is it decorative, or does it have some purpose?
With the 3D viewer you can get a better Idea how the board would look like if it is being manufactured. Press [Alt + 3] to in Pcbnew to see it in the 3D viewer.
It is not totally finished. I will had vias in certain places to connect certain top tracks with certain bottom tracks. This is just a passive PCB to do specific connections (for the rotors of an Enigma machine)
Not what i guessed at first but damn it makes sense now.
(With the first pictures i suspected some strange antenna design or something like that.)
Like most kicad tools the highlight net tool relies on an existing schematic. (or more precisely a netlist. Can also be generated by hand or with tools like wirelt) So you might be a bit out of luck here. (Assuming i understood this thread correctly and you do not have a schematic.)
