I have a component (J5 on Pmp_Vlv sheet) that I have laid out in my schematic that the net are not correct on the PCB
I have tried everything I can think of short of deleting the PCB and starting over.
Does anyone have an easy fix for this?
Pool.zip (292.9 KB)
gmc
2
Difficult to troubleshoot as you haven’t attached the footprints. Try editing the footprint on the PCB and update footprint from library.
@gmc Changed the footprint to a different 6 pin header in the schematic and the something with the nets.
BobZ
4
Did you do go to tools and select update pcb from schematic?
What KiCad version is this, I am seeing 2021 dates in the files?
After very change I made to correct the issue
Application: KiCad (64-bit)
Version: (6.0.10), release build
wxWidgets 3.2.1
libcurl/7.86.0-DEV Schannel zlib/1.2.13
Date: Dec 19 2022 21:23:04
wxWidgets: 3.2.1 (wchar_t,wx containers)
Boost: 1.80.0
OCC: 7.6.2
Curl: 7.86.0-DEV
ngspice: 38
Compiler: Visual C++ 1929 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
I found the issue
If you look at the image you will find that I label the nets with net labels instead of just using plain text and apparently net labels have priority.
I removed the labels and the nets returned to the schematic layout.
In 7.0 you can use a “Directive Label” to do labelings like that which will not override the net name.
system
Closed
10
