Is there a global command to make all component values invisible on the PCB?
The components values are on the Fab layer, so they are invisible by default when you manufacture a PCB. If you want to hide them in KiCAD then switch F.Fab and/or B.Fab layer off.
Also there’s a toggle to display hidden text in Appearance → Objects. Make sure you have that switched off.
Thank you Greg. Thank seems to work.
I can’t see the “Appearance->Objects” only the “selection filter” usual like tracks, pads etc…
And the three above “Hidden”.
There are on/offs for Value, Ref & Text.
Under the word Appearance are three tabs: Layers, Objects & Nets.
Left click the middle one.
Ha ha! @Dawid_Cislo beat me
Hehe. Just where it said it was and works 100% thanks you for all the inputs…
Although better suited for editing, various things can be turned on and off in Edit > Edit Text and Graphic Properties.
(That’s in the top LH corner )
