I created two footprints, one for smd capacitors and one for SMD resistors. No worries with the capacitor footprint; but error message for the resistance footprint. For them its similar.
Attached are the 2 files of footprint
My french is quite horrible, but I’m guessing some kind of zone is defined wrongly on your PCB because it’s not a “closed outline” and the problem is not caused by any of these two footprints.
I did see a few irregularities:
The footprints do not have any graphics on the courtyard layer.
The Resistor lines on the Silkscreen do not have perfectly matching endpoints in one corner. (Upper left in the library)
The Resistors has a bit of a slanted side. (Right side in library)
Setting the grid to some appropriate value makes drawing lines for footprints easier.
Before I ask anything here or report a bug I switch KiCad to English. I believe much more people will understand me than if I ask about messages from the Polish version.
