I ran into the problem of not being able to increase the width of the pattern during artwork.
Can the allowable current be made by increasing the copper foil thickness instead of increasing the pattern width?
I look forward to many replies !
Yes.
Double the thickness = double the width (in most cases, in case anyone begs to differ
thank you bro ! I think I can solve this problem now !
I have one more question. What happens to my pcb when i reduce the thickness of the core in pcb?
It will lose a little of its structural integrity, won’t affect the electrical side of things.
It’s so hard to say, can you explain it to me in an easy way?
Sorry, sometimes I forget there are a lot of English Second Language members.
The PCB will not have as much mechanical strength. The PCB will be able to flex a little more.
Electrically, there will be no problems.
Thanks for the good info !
Assuming, of course, that it’s not impedance controlled or something like that. Which we can safely assume, considering the questions.
Can I change the orientation of a part?
inversion not rotation
The PCB editor doesn’t have a mirror function as mirroring components usually doesn’t make much sense. If you want to mirror an artwork graphic, the easiest way would be to use an external program while working in dxf or svg format.
