are there any changes on path substitution on nightly builds?
I set the environment as followed:
the result even after a reboot:
thx
thx
What do you have in C:\Users<your user name>\AppData\Roaming\kicad\kicad_common ?
Thank you, that was it. Question: Do i need to set the environment variables or only need to edit the kicad-common?
Good question, I am still trying to work out. It appears that the variables in kicad-common override the environment variables.
Thx, good to know. This helps other lost user
