Is there a way to pass the Value of a eeschema symbol to the .subckt as happens now to the Value field in Edit Spice Parameter/Passive/Value? I mean something as a place holder or a Kicad variable or anything else. In this way should be possible to use a reduced set of .subckt and probably just one library for any passive component requiring a better model than the default model (that has parasitics and temperature coefficients pre-loaded with default values).
