Anyone had StepUp miss parts before? I have a grove connector, which has a step file in the KIPRJMOD, but it’s not loaded when i do ‘Load kicad Board *.kicad_pcb’. Another part that also has a step file in the KIPRJMOD loads just fine. The grove part looks fine in freecad and in the 3d viewer of KiCad. I have no idea why it’s not loading it, it’s not evening mentioning any errors in the freecad console, it’s just not there.
This is what I get from the FreeCad console:
kicad StepUp version 4.0.2.6
tolerance on vertex applied
ksu file 'ksu-config.ini' exists
materials section present
turntable section present
compound section present
docking section present
font section present
prefix3D_2 found KIPRJMOD
3D models prefix=/Library/Application Support/kicad/modules/packages3d/
3D models prefix2=KIPRJMOD/
pcb color=0.0,0.298,1.0,lightblue (0,76,255)
blacklist modules
volume 0 heigh 0
bounding box option 0 whitelist
placement board @ useBaseOrigin #place board @ 0,0,0
idf_to_origin True
last fp path /Users/jorishoogeboom/Downloads/Socket_Strips.pretty-master
last brd path /Users/jorishoogeboom/Work/scape/scape/minibuqs/electronics/kicad
virtual models noVirtual
export fusing option nofuse #default
minimum drill size 0.0mm
export to STEP True
enable materials True
turntable True
compound allowed True
docking mode float
fonts size 8
blacklist modules
volume 0 heigh 0
idf_to_origin True
export to STEP True
turntable True
docking mode float
fonts size 8
opening /Users/jorishoogeboom/Work/scape/scape/minibuqs/electronics/kicad/motor.kicad_pcb
my file path /Users/jorishoogeboom/Work/scape/scape/minibuqs/electronics/kicad
FC Version 016
kicad_pcb version 20160815
PCBThickness1.6 mm
wrong scale!!! set scale to (1 1 1)
wrong scale!!! for Diodes_SMD.3dshapes/D_SMA_Handsoldering.wrl Set scale to (1 1 1)
PCB Loader
2d closed path
max Length=22.1647844006 index=0
running time: 0sec
start cutting
running time: 0sec
running time: 1sec
model name D_SMA_Handsoldering
error missing /Library/Application Support/kicad/modules/packages3d/Diodes_SMD.3dshapes/D_SMA_Handsoldering.step
${KIPRJMOD}/SOT-23.wrl
adjusting Relative Path
step-module-replaced /Users/jorishoogeboom/Work/scape/scape/minibuqs/electronics/kicad/SOT-23.wrl
model name SOT-23
opening /Users/jorishoogeboom/Work/scape/scape/minibuqs/electronics/kicad/SOT-23.step
SOT-23
module /Users/jorishoogeboom/Work/scape/scape/minibuqs/electronics/kicad/SOT-23.step
Capacitors_SMD.3dshapes/C_0603.wrl
model name C_0603
opening /Library/Application Support/kicad/modules/packages3d/Capacitors_SMD.3dshapes/C_0603.step
C_0603
module Capacitors_SMD.3dshapes/C_0603.step
model name C_0603
C_0603
Resistors_SMD.3dshapes/R_0603.wrl
model name R_0603
opening /Library/Application Support/kicad/modules/packages3d/Resistors_SMD.3dshapes/R_0603.step
R_0603
module Resistors_SMD.3dshapes/R_0603.step
model name R_0603
R_0603
model name R_0603
R_0603
running time: 3sec
missing models
error: reset values of scale to (xyz 1 1 1)
exporting to MCAD
/Users/jorishoogeboom/Work/scape/scape/minibuqs/electronics/kicad/motor.FCStd
Board Placed @ 0.0;0.0;0.0
kicad pcb pos: (0.000;-2.000;0.00)
running time: 5sec
I’ve attached the board pcb here
motor.kicad_pcb (30.4 KB)
