As long as I can attach a net to them and therefore wire them into the chip they can be tracks or polygons or whatever…
I can probably generate the shapes in Solidworks. Export as dxf or pdf or png or something like that. Was hoping there was a native kicad thing to do it because relying on Solidworks is a pain, as is generating png from an excel (with the added complication that it’s a fundamentally polar coordinate problem).
There’s a function plotter in Inkscape (Extensions → Render → Function Plotter) with a polar mode that can be used for quick work (it’s not as accurate as a proper mathematical solvers, because the derivative is numerical for polar plots and there’s no adaptive sampling). But with enough sample points the error will be negligible:
There are plenty of Posts on using DXF and Graphics so, I’ll stop at getting a Sine Curve, using FreeCAD (yes, there are many other ways to get the Curve).
Since you know SolidWorks, then you know 90% of FreeCAD’s ‘Part-Design’ Workbench. That said, video shows using the ‘Draft’ workbench and the Python Console in FreeCAD.
I simply dropped in the Code below and hit Enter-Key…
(FYI - I came to FreeCAD years ago after using SolidWorks, Pro-E and all the other’s… I use only FreeCAD now).
Oh, and there’s a nice Parametric Workbench with built-in functions that are editable… I use it to make Traces/Tracks in Kicad
import FreeCAD
import Draft
import math
pts = []
radius = 10
for ii in range(0,360):
pts.append(FreeCAD.Base.Vector(iimath.pi/180,math.sin(iimath.pi/180),0))
Next time you encounter such spam click on the menu icon under the post (the three dots) then the flag icon to report as spam and hide the post. Anybody can do this. A mod will subsequently eject the malefactor.
