Nici
January 19, 2024, 10:28am
1
Everytime I drag the view over the edge using the middle mouse it teleports my cursor to the other side of the view and moves my actual schematic out of the view.
Watching this short video I made showcasing the bug I’m facing is easier than describing it.
Things I’ve tried:
eelik
January 19, 2024, 10:51am
2
I guess you use some Linux distro with Wayland. Wayland isn’t officially supported because of some/many problems. There are some fixes for v8 (at the moment the pre-release RC1). I don’t remember if your exact problem is caused by Wayland and if it has been fixed, but it sounds like one of those problems.
Nici
January 19, 2024, 11:54am
3
Thanks a lot for pointing me in the right direction! I found an open issue describing this exact bug thanks to it: Canvas jumps when panning near the edge on Wayland systems (#15899) · Issues · KiCad / KiCad Source Code / kicad · GitLab
I actually didnt even realize it wasn’t runnin natively on wayland, props to the developers for making it almost completely seemless
I should’ve mentioned what system I was using sorry about that. Here it is in hindsight for the record:
neofetch
-` nici@dell-xps
.o+` -------------
`ooo/ OS: Arch Linux x86_64
`+oooo: Host: Laptop (12th Gen Intel Core) A4
`+oooooo: Kernel: 6.7.0-zen3-1-zen
-+oooooo+: Uptime: 13 hours, 46 mins
`/:-:++oooo+: Packages: 2858 (pacman), 14 (flatpak)
`/++++/+++++++: Shell: zsh 5.9
`/++++++++++++++: Resolution: 2256x1504
`/+++ooooooooooooo/` WM: sway
./ooosssso++osssssso+` Theme: Catppuccin-Mocha-Standard-Mauve-Dark [GTK2/3]
.oossssso-````/ossssss+` Icons: Papirus-Dark [GTK2/3]
-osssssso. :ssssssso. Terminal: alacritty
:osssssss/ osssso+++. Terminal Font: JetBrainsMono Nerd Font
/ossssssss/ +ssssooo/- CPU: 12th Gen Intel i5-1240P (16) @ 4.400GHz
`/ossssso+/:- -:/+osssso+- GPU: Intel Alder Lake-P
`+sso+:-` `.-/+oso: Memory: 6595MiB / 15701MiB
Kicad Version Info:
Version: 7.0.10, release build
wxWidgets 3.2.4
FreeType 2.13.2
HarfBuzz 8.3.0
FontConfig 2.15.0
libcurl/8.5.0 OpenSSL/3.2.0 zlib/1.3 brotli/1.1.0 zstd/1.5.5 libidn2/2.3.4 libpsl/0.21.2 (+libidn2/2.3.4) libssh2/1.11.0 nghttp2/1.58.0
Platform: Arch Linux, 64 bit, Little endian, wxGTK, , wayland
Date: Dec 30 2023 03:23:58
wxWidgets: 3.2.4 (wchar_t,wx containers) GTK+ 3.24
Boost: 1.83.0
OCC: 7.7.2
Curl: 8.5.0
ngspice: 41
Compiler: GCC 13.2.1 with C++ ABI 1018
KICAD_USE_EGL=ON
KICAD_SPICE=ON
eelik
January 19, 2024, 12:13pm
4
Even more important is usually the exact KiCad information which can be copied to clipboard from Help → About KiCad → Copy Version Info (button).
Nici
January 23, 2024, 7:53am
5
Added that info, thank you :)
system
Closed
April 22, 2024, 7:53am
6
