When I convert a shcematic to KiCAD 6.0 version format, I found the page number is incorrect.
Here is the original file which is opened with KiCAD 5.1.12:
And here is the one I opened with KiCAD 6.0:
Please pay attention to the Id in the right and bottom corner, they are the same schematic file, the only different thing is one is opened with KiCAD 5.1.12 and the other is opened with KiCAD 6.0.0, but one’s Id is 2/6 and the other’s is 6/6.
(Please ignore the differences of the work sheet, because I have update the work sheet template to version 6.0’s format, so when I used KiCAD 5.1.12 to open the sheet, it can’t recorganize the work sheet template, so it used default work sheet of KiCAD 5.1.12 instead, but I promise I haven’t modify the ID format of the work sheet)
When I opend 6.0.0’s schematic file with text editor, I found that in the source file, it shows ‘sheet 2 6’:
So, I think maybe this is a bug for KiCAD 6.0.0.
Here is the KiCAD 6.0.0’s infomation:
Application: KiCad 原理图编辑器 (64-bit)
Version: (6.0.0), release build
wxWidgets 3.1.5
libcurl/7.78.0-DEV Schannel zlib/1.2.11
Platform: Windows 10 (build 18363), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Dec 24 2021 19:17:02
wxWidgets: 3.1.5 (wchar_t,wx containers)
Boost: 1.76.0
OCC: 7.5.0
Curl: 7.78.0-DEV
ngspice: 35
Compiler: Visual C++ 1929 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
