I’ve sketched up a new page layout that aligns more with how our other page layouts look in different cad programs. I’ve gone through the documentation but I can’t seem to find any information alluding to linking what I have in the page layout to the page settings GUI.
I’ve uploaded an image to clarify. When I import my layout to a circuit diagram I don’t have the ability to fill in most of the comments. The page settings GUI only shows comments up to 4 and there doesn’t seem to be any customization with its naming convention. Ideally I would have “Approved Date” instead of “Comment 4”.
Am I missing something or is this just not implemented yet? seems odd that in the documentation the comments can go up to 9 if I can’t fill them in.
From the KiCad main window with those eight big buttons top right. Select the right most to design at your hearts desire. In there you can change those field names as well.
It’s the ‘Edit worksheet graphic and text’ button.
Hi jos, that’s is what I went into to design my page layout. I can’t see any way to change the gui for filling out the comments after 4. The layout is all setup the issue is I can’t fill in some of the boxes with data
As it stands it’s hard coded. Just did a quick compile with changed text. All good.
To have it changeable is one thing, though another things is to cater for all the translations e.g. at least for the default text after an installation. Not exactly straight forward a change.
One way to change it could be to adjust your ‘local’ translation. Should work in principal.
This would presumably being addressed in the next major version.
Edit:
Then again. What is stopping you from input like ‘Approved %C3’ (Comment4)
Is that something that has be changed before compiling or could I edit a file with notepad++ somewhere to show fields for more of the user reference values.
Blockquote %% = replaced by %
%K = KiCad version
%Z = paper format name (A4, USLetter …)
%Y = company name
%D = date
%R = revision
%S = sheet number
%N = number of sheets
%Cx = comment (x = 0 to 9 to identify the comment)
%F = filename
%P = sheet path (sheet full name, for Eeschema)
%T = title
that’s what’s in the documentation. As you can see it clearly says comments can go up to 9 which seems counter intuitive if you can’t even fill in these user references.
Just to be clear I would just like the ability to add in fields for the comment references going up to 9. Not too bothered about them being named so long as I can use them.
I’m not sure where to find Comment4 in this i18n. do you know which part of that code actually generates the text box in the page settings gui? I need about 4 or 5 more boxes pushing text to comment field 5,6,7,8
