Padstack- again, again
How I can make padstack? It is, eg. 1.2 mm plated hole, bottom side 2 mm annular ring, top side 1.6 mm annular ring?
  • I try “edit shape as pad”, but shape must be top side and it make effect to all layers
  • Other jinx? SMD pad with same number, so 1.2 mm plated hole 1.6 annular ring + 2 mm smd pad bottom side?
  • Manupulate Kicad footprint or pcb ascii-file manually?
  • Other jinx?
So, need “true padstack” but how?
Something like this ?
Its a normal plated through hole with pads and an additional large SMD circular pad on one side . . . all pads have the same number.
KiCad does not have support for a full padstack (yet). At the moment it only has a function to remove annular rings on layers without an attached track.
As a workaround you can use multiple pads to form a more complex pad. For example use a THT pad for the smallest pad you want, and then add a SMT pad with the same pad number on the layer you want a bigger pad. Using pads with the same pad number to create more complex pads is a common technique in KiCad. It is for example used in all default footprints with the keyword “thermal” in it.
