I would like to import the BeagleBone Black Wireless to the KiCad Pcbnew. It’s a six-layers design with several copper-zones. After importing to the Pcbnew, it first shows a warning saying that several “Unsupported Eagle layer” are translated to “Dwgs.User layer”, as below.
3:27:58 PM: Unsupported Eagle layer ‘tKeepout’ (39), converted to Dwgs.User layer
3:27:58 PM: Unsupported Eagle layer ‘tRestrict’ (41), converted to Dwgs.User layer
3:27:58 PM: Unsupported Eagle layer ‘tTest’ (37), converted to Dwgs.User layer
After carefully checking the design in KiCad, I found that all the pads lose the “Net” definition, which was originally defined in the EAGLE .brd file. I tried to remove all the routed traces in EAGLE and imported to KiCad again, but the problem persists. Does anyone have a similar experience? Is it a known issue? Thank you!
Here is my KiCad environment:
Application: KiCad
Version: (5.1.0-1316-gbacbe8675), release build
wxWidgets 3.0.4
libcurl/7.61.1 OpenSSL/1.1.1 (WinSSL) zlib/1.2.11 brotli/1.0.6 libidn2/2.0.5 libpsl/0.20.2 (+libidn2/2.0.5) nghttp2/1.34.0
Boost: 1.68.0
Curl: 7.61.1
Compiler: GCC 8.2.0 with C++ ABI 1013Build settings:
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
