Pads fill in zones
I’m sorry for my poor English, maybe the solution is already in the forum, but I didn’t find it. Perhaps is why I don’t know the correct words.
How can I avoid that pads are only “crossed” in the ground layer, but the contact is all around?
But I want copper all around, not only a cross.
Is there a solution?
Pietro
  1. Select the zone.
  2. Press e to edit the zone properties.
  3. Change Pad Connections from Thermal Reliefs to Solid.
Maybe you know that, anyways: solid connections to a plane make soldering very difficult, as the plane draws a lot of heat from the solder joint.
