When i am trying to use a new layout with 8.0.6, some devices that look pine in the schematic viewer end up unusable in the PCB editor. The show up similarly messed up in the footprint editor.
For example, the default MAX1487E (footprint Package_SO:SOIC-8_3.9x4.9mm_P1.27mm.wrl) shows up with the pins diagonally 94mm away from the part outline at -94 degrees.
I use KiCAD mainly for schematics and then use existing models for my layouts. I do not use it all the time, so i apologize if this is a simple question. Several parts are working just fine, but Adafruit_Feather_Generic has the same problem. I could not find anything in the topics.
This is how it shows up in 8.0.6 on my machine:
Pins are around 6.2mm from each other (centre to centre of diagonal pads). Looks straight, not -94deg to me.
