Pad to via clearance setting in kicad i am not getting
We are not getting what your problem or question is, can you elaborate?
They are all on the same net, there doesn’t need to be clearance.
Good guess. Or maybe they want to set same net clearance…
What is this:
Pad to via clearance setting in KiCad
When does KiCad treat these as special? Both pads and via’s just follow the normal clearance rules of the netclass they are in, unless maybe you set up some custom rules. Also a bit of
image for eelik, because the description is not clear enough to give a decent answer.
