I am presently using some Wurth PCB pillars and the footprint is part of the main library
Mounting_Wuerth_WA-SMSI-M3_H12mm_9774120360
I have been going through my placement correcting all the DRC’s before getting into detailed work to minimise rework later on.
I have 7 DRC left and all come down to the same footprint
Looking at the footprint, it is as per the datasheet but DRC is failing. It would appear to be due to the fact the part has copper to the drill hole rather than a gap.
Is there anyway to turn off this DRC in 5.1.6 ( I believe the ability to ignore DRC exist for v6)
The Footprint is more complicated then I’d expect.
I can not help much here.
Pads without pad numbers are handled in some special way in KiCad, but I do not know much about that detail. Maybe there is something about the manual about this, or else wait for others to respond.
This is a known issue with the non plated options. Just ignore the DRC error we did not really come up with any option that would not trigger something.
