Pad clearence hiding kicad 9
I’m having an issue with pad clearance visibility in KiCad. Despite having “Show pad clearance” option checked in my preferences, I can’t see any clearance lines around the pads in my PCB design.
Here’s what I’ve tried:
  1. In Preferences > Display Options, I’ve enabled “Show pad clearance” (checkbox is checked)
I’ve attached screenshots showing my settings and the PCB view where the clearance lines should be visible.
Is there another setting I need to enable, or could this be a rendering issue? Any advice on how to make the pad clearance lines visible would be greatly appreciated.
Screenshot 2025-03-27 101835
Clearances only show up on the active layer. Maybe you have a different layer selected?
Check: Board Setup > Design Rules > Net Classes > Clearance
If this is set to 0 there will be no clearance, hence no lines.
No the clearance is not zero.
I have f.cu. layer as active layer you can see in the post, other layers are dimmed below.
Please use the “Help->About KiCad->Copy KiCad version” button and post your KiCAD information here, in case of v9, have you try RC1 and/or RC2 ?
Version: 9.0.0, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
libcurl/8.11.1-DEV Schannel zlib/1.3.1
OpenGL: ATI Technologies Inc., AMD Radeon™ Graphics, 4.6.0 Compatibility Profile Context 24.9.1.240813
Date: Feb 19 2025 17:46:53
Boost: 1.86.0
OCC: 7.8.1
Curl: 8.11.1-DEV
ngspice: 44
KICAD_IPC_API=ON
Locale:
Lang: en_US
Enc: UTF-8
Num: 1,234.5
Are you aware, that pad clearance is only visible during routing?
Issue created and solved here
