Hello, I’m ordering components for an electronic gong. I just wondered what the output component  of this schematic could be? It’s the circled component with a blue line. Thanks in advance.
It is just a generic pin to some output connector.
Compare it with the “Zero” and the “Plus” (12…15V 20mA)
The 100kOhm potentiometer suggests it is a pretty high impedance audio output, and yo will need some amplifier and a speaker to get noise out of it.
741 is also a pretty old opamp, but probably any opamp will work. I would use some opamp that can run on lower voltage. I think the 555 also works from a voltage as low as 5V.
